Charge for remedial work on hourly rate.... *sucks teeth* “could take weeks to find it, Mate”
Bound to find it with a wonder leadWonder lead it as you’ve already had the sockets off you will know which are spurs....The highest two readings of the sockets that are part of the ring are likely to be the two sockets either side of the break.
Agree,it’s the bashing around,tiles,carpets,cupboards,to get at the fault.Bound to find it with a wonder lead![]()
ask them to put a bed up for you it cold take month's.around,tiles,carpets,cupboards,to get at the fault.
might be possible to change to radial circuitask them to put a bed up for you it cold take month's.
I really hope that’s where it isThird bedroom, just inside the door under the floor...
ThanksI really hope that’s where it is![]()
…...or even two?might be possible to change to radial circuit
I took post #1 to be slightly tongue in cheek born out of the resigned feeling we all get when faced with a pig of a job. I don't think Cliffed is expecting an answer on here!…...or even two?
I can understand you making a statement but asking for help is a bit much. You're the one on site.
Asking for advice,that’s what this forum is about,you learn everyday.…...or even two?
ThanksI had to split a ring final to two radials a while back, open continuity on neutral conductors. I had ten outlets on one radial and two on the other![]()
