RDB85
Trainee
So I’ve completed my Level 3 302 exam and got a Distinction. I’m just starting my project now. It’s a Pool, Hotel Rooms and Dining Room/Kitchen.
Seem okay so far. Any advice from people that have done it?
Design it as if you’re installing it. Keep it as simple as possible, diversity is king, no expense spared, use technology such as smart switching, swap incandescent lighting etc for LED to save the planet and reduce demand, this list is endless.
Thanks for the advice. I’m just working on Q1. Which is circuit diagram, three phase supply system and earring arrangements from substation to transformer to charging unit. It should show the total earth fault loop for the charging unit.
Diagram needs to indicate connection points for each item of equipment.
So I am thinking 3 phase with an MCB or CCU, then goes into the EVC Unit. The EVC unit will have its earth TT system. Which I think is in the 18th Edition.
I’m going to draw it out on scrap paper. Any other suggestions?
RDB85
Trainee
Liverpool
Trainee Electrician
Level 3 Project - Advice
RDB85,
RDB85,
