M
Mikey10695
Hi, we have been asked to relocate a consumer unit however the meter cupboard will be on an outside wall 7m away from the consumer unit, the main switch is under 80amp, im just wanting some opinions on the way to overcome this, am I right in thinking I could run 16mm swa from the consumer unit, cleated to an outside wall, running to an adaptable weatherproof box situated next to the meter cupboard, then using Henley connector blocks, i could connect the swa to the tails coming from the meter box.
