K
Ksims94
Hi all,
After some advise.
I have recently built a retaining wall with steps out of concrete blocks laid flat. Around 700mm tall
The wall will hold back around 500mm or so of ground, leaving a nice 180mm ish of wall above ground level.
My plan is to install lights ( brick lights I assume ) in the wall, trying to hide connections while also being able to maintain them if the lights were to break or cables to fault, and it all be waterproof?
I am hoping with a finished result of lights in both sides of the wall ,but, at different levels, and some lights for the steps .
What would be the best way to go about this ?
All suggestions welcome regard all aspects of the installation ( lights, cable to be used, waterproofing etc)
I will prove some pics ASAP
Thanks all
After some advise.
Thanks all
