Hi Gary, Bahco and Knipex are two great cutters, but only if you use them for their intended use! Cutting fencing wire, welding rods, and piano wire will kill the edge---Iv'e seen it done---why do you think there is a heavy duty pair of shears on the side of the linesman's pliers (I think you may call them combination pliers these days).
I must be doing something wrong. Not owned or used a pair of side cutters for a very long time.
Granted, ive only been back on the tools full time for 3 years, but I remember using them years ago for speed stripping MICC.
I get by using a pair of combination pliers
Not necessarily, whatever you are comfortable with, I use a pair of cable shears, these run round the cable just fine, and as long as you don't put too much pressure on, do a nice cut and strip. Talking of pyro, do you remember the Cumic wedge-seal kit? Worked well if you got the tension right, (it was a modified Mole grip) some people had pots falling off while others anihilated the cable end! Didn't last long, so back to the forked lump of bar and that ---- pot crimp!
I've had my Bahco sidecutters for about 15 years and have given them a heck of a battering and they are still pretty sharp and very useable now. I absolutely wouldn't hesitate to buy a new pair if they do finally pack up, in fact, I wouldn't even look at any other make, a fantastic bit of kit. ( And no, I don't work for Bahco lol)
I have used Bahco gear for many years,and settled on the piano-wire capable 160mm or 180mm models,with the de-clutching return spring.
I renew them,about every 8 years,and have kept every previous set....including one with a neat "stripping notch".....yeah...we all know how i earnt that...;)
IV gone for bahco in the end.
To be correct, what you call “shears on the side” ARE “side cutters” and what you call side cutters are actually “Diagonal cutters”
I have a pair of the large sized Bahco ergo sidecutters, bought after a reccomendation the edge was supposed to have one end for stripping and a slightly different geometry near the joint for cutting,
Great for cutting cables but I just didn't get on with them for stripping wires so they got relegated to the garage,
Maybe I was unlucky I'm a Bahco fan normally but not with these!
Bad luck on that one! sometimes you can get a tool that just 'does it' for you--sometimes you can't gel. I tried one of the go faster wonder SWA cable strippers--I'm back to using a junior hacksaw with an interesting shaped blade (I sat on it in the car) and a very sharp knife. Whilst on the subject of Bahco tools and SWA, I can recommend Bahco's 6" adjustable spanner, it opens really wide and the jaws are tapered and slim--brilliant.
Can you still get Elliot Lucas pliers and cutters?
think so. also some stuff on amazon
and of course ebay:
John Matrix,
Martin Kerr,
