Only napit as far as I am aware have the appropriate certification for 3rd party.
STROMA too, if you can still count them as separate from NAPIT.
So when competent retired electrician Pete with all his experience wants to run a new lighting and ring final circuit to his shed extension that housed his tool collection has to call a Stroma/Napit electrician up to wire it or pay £--- to building control. I do commercial works now ( I did new houses for years before that) so I am not in a scheme and I don't think both of us have a mate in Stroma/Napit.
Would you advise me to do the board change then (as well as installing the bonding) and get a friend of mine who is in the NIC to test and certify it?
You could always ask you mate to come over and just sit there watch you as you do the board change and subsequent testing, just ensure he is thoroughly fed and watered every few hours, as long as he sees what you’re doing at each stage, he should be able to sign it off for you.
? I’m sure aslong as you’re competent and fellow sparks who do hold relevant qualifications to sign off work trust and know you then verify the testing and inspection results it should not be an issue it is all red tape and understandably due to dodgy cowboys of previous years. The regulations now are very strict and rightly so but common sense usually prevails without getting too politicalYou could always ask you mate to come over and just sit there watch you as you do the board change and subsequent testing, just ensure he is thoroughly fed and watered every few hours, as long as he sees what you’re doing at each stage, he should be able to sign it off for you.
Rather than make someone physically sit and observe for 4 or 5 hours which would be extremely weird imo...
Just record yourself , edit it to about a 10 minute video mainly showing the testing part etc and email it to the guy signing off the job
Maybe he could add background music to the video?
