Hi, I'm retired, but have worked as an electricians mate off and on - I know my limitations. I've been asked by a friend to fit a "picture light". The wall is plasterboard cavity with insulation, the wall has a 3 inch coving.
I have access to the loft above and there is a single pendant in the room where they want the picture light switched from. What is the best way to run the cable down the wall from the loft (taking a feed from the pendant). Not sure how to identify the wall plate in the loft and drill down through it. Any advice would be appreciated.
Use a cable detector on the ceiling next to where the light will be fitted to ensure you are not about to drill into a cable or pipe.
Stud finder for wall to ensure you are not trying to come down in the same place as a vertical timber.
When you have lifted the insulation in the area you need to drill down, the layout of the room below should be apparent.
Drill down with a 1 inch drill so you can see into the cavity below.
Drill a small hole where the picture light will hang.
Get mate to shine torch in hole whilst you look down from above to make sure there is a clear run for the cable.
Remember, always check that there are no services behind wall where you are about to drill.
Many a 1 hour job have been turned into a 2 DAY job by
“Finding” a cable or pipe with a drill bit.
It’s a job of good measurement and pot luck finding the top of the wall from the attic when all you can see is the top side of the plasterboard ceiling.
I did this once for a switch drop and managed to hit the void behind coving. A matter of 2 inches and redrilled into centre of wall and no damage to decoration.
If the wall has insulation in it, that could be a difficulty. A good set of cable rods or trunking lid. And more of the luck I talked about earlier.
New regs do stipulate RCD protection for luminaries now, so that to consider.
Good luck, and if your luck holds out, you might think about buying a lottery ticket
before you even start working on the light is it going to be RCD protected going in the wall .
Thanks for all your replies. The lighting circuit is protected by an RCBO
[automerge]1569403107[/automerge]
I agree...there's no such thing as a "5 minute job"
