So new build bungalow is to have 300mm loft insulation as told by building control. This means installation method 101 comes into place however as it's a bungalow all circuits including cooker ring mains etc will be installed this way as they come from the loft space down. This installation method 101 isn't ideal as cables will have to beefed up so much. So only other way is to use a different installation method. So I was just wondering what installation method you guys would recommend or a good way to install circuits in a loft that will have 300mm of insulation.
