gloves are no use to me. theskin on my hands is tough as old boots. it's the forearms that suffer from bleeding after contact with anything sharp.
I need to protect my hands from direct exposure to live electrical wires, sharp edges, and tools while still being able to perform my duties undeterred.
Direct exposure to live wires is prevented by safe isolation and following safe working practices.
So give us some more details about the work you are doing that needs these gloves OP.
(Admin edit - Don't link build here - Thanks for the content. :) )
I need something like in this-
What are the 5 Best Electrician Gloves?
1. PIP G-TEK Maxi Flex Endurance Gloves
2. OTC Large Hybrid Electric Safety Gloves
3. Ansell ActivArmr Gloves
4. Klein Tool Lineman Electrician Gloves
5. ILM Safety Work Gloves
For an electrician, there is no telling the extent of danger you are always in due to the constant interaction with live electrical wires and equipment. On a daily basis, you expose your hands to burns, electrical shock, and other injuries conditions. It is imperative always to find a way of protecting your hands from direct exposure to live electrical wires, sharp edges, and tools while still being able to perform your duties undeterred. And what better way to give the necessary cover to your hands than using high-quality, excellent dexterity electrician gloves?
There is excellent wide-ranging gloves that are just suited for electrical works while a majority of these can also be used for all purposes and applications. Electrical gloves are all over the market, and with quality assurance being the major issue, it is very hard to choose the perfect pair for your hands. To save you the trouble of searching all over the online stores for a glove fit for the job, we thought it would be best to review the highest rated electrician gloves and pick the best glove anyone working in this industry should try out.
Shop Related Products
Lineman Work Glove Extra Large Klein Tools 40084
$28.21
(110)
Ansell ActivArmr 97-004 Multipurpose Mason Gloves, …
$24.99
(12)
OTC 3991-12 Large Hybrid Electric Safety Gloves
$111.99
(49)
PIP G-TEK Maxi Flex Endurance 34-845 Seamless Knit Coa…
$16.41
(9)
Ads by Amazon
ilm-safety-gloves
If you are an electrician who works on a wide range of components, the ILM Safety gloves are the best tool to have. Designed with a PU coating for maximum shock protection, these safety gloves are not only breathable but also highly lightweight with a well-knit polyester liner.
For handling small electronic and electrical components, the ILM gloves provide a general good grip and workmanship. They have an extra support for dexterity and precision which is one aspect of electrical work that should never go wrong. You can rely on these work gloves for a range of electrical applications such as assembly, packaging and general handling of electrical and electronic equipment.
Pros
  • Made with high durable material
  • They are lightweight
  • Have a good fit
  • Breathable design with the back of the gloves open
  • Provide immediate comfort thus do not require a beak-in period
Cons
  • The stitches come of easily
  • They lack cold temperature protection
  • Fraying fabric
Generally, the ILM gloves is a good fit and sizing is not a problem unless you have really huge fingers. Highly recommended for light weight electrical works which do not involve contact with high voltage live wires.
CHECK PRICE ON
CHECK PRICE ON
CHECK PRICE ON
klein-tool-gloves
These extra-large gloves are what you need if you will be going about pulling electric cables and doing some electrical repairs but also try and avoid touching live wires directly. The gloves come in a uniquely designed finger and palm material which provides quality resistance to slip and durability. For a better on and off experience, you will get the extended cuffs on the gloves designed just for that purpose.
The main features of this pair of gloves include the integrated, high-quality composite materials with leather 85%, nylon 5%, spandex 5% and neoprene 5%.
Pros
  • Klein Tools company covers defects in workmanship and quality
  • Breathable Spandex material
  • The thumb base is provided with additional reinforcement
  • The glove is machine washable
  • Durable and resistant to slip
Cons
  • Not to be used on live circuits
  • Poorly stitched on the fingers
  • Requires a break-in period to achieve
Klein has been manufacturing the finest hand tools since the 19th century, and the Klein Electrician gloves are just one artwork of their expertise in this field.
CHECK PRICE ON
CHECK PRICE ON
CHECK PRICE ON
ansell-activarmr-gloves
The Ansell ActivArmr electrician gloves are high-performance gloves which stand the test of time in all harsh conditions you can think of. What makes this glove suitable for all work conditions is that it can protect you against cuts, punctures, shocks, and abrasions. This is made possible by the polyurethane palm and fingertip coating which offer better resistance to wear than leather.
Ansell ActivArmr electrician gloves are made using a high-end quality Dyneema which is an ultra-high molecular weight polyethylene fiber that gives the material its strength and durability. In every aspect, this material beats all its alternatives thus making Ansell gloves the best tool for an electrician’s safety. The unique knitted variable stitch design enhances its dexterity and breathability. What is even more impressive is that these gloves can help in worker identification because it has an ID nameplate on the inner cuff.
Pros
  • Greater resistance to abrasion than aramid fibers
  • Better than steel in terms of strength
  • Offers quality cut protection compared to leather
  • Adjustable wrist closure
Cons
  • Seams may come off depending on the frequency of use
  • Very small sized users may find them unfitting
Uniquely and well designed, the Ansell electrician gloves will feel like an extra layer of skin on top of your natural skin but with an added impressive grip. You can enjoy its wide range of applications in pulling cables, wiring boxes, stripping wire, installing, circuits, conduits, sockets and a host of other electrical equipment.
CHECK PRICE ON
CHECK PRICE ON
CHECK PRICE ON
otc-electric-gloves
If you are not one to easily compromises on their safety when it comes to handling electrical works, the OTC hybrid is the hand partner you need. These gloves are highly recommended for those working on heavily energized compartments and high voltage vehicles. The OTC hybrid safety gloves adhere to ASTM standards with leather protection and rubber insulation.
Pros
  • Resilient rubber offers electrical insulation
  • Leather enhances resistance to wear and tear and makes them durable
  • Palm and finger reinforcement patches
  • High-quality standards
  • Unmatched dexterity
Cons
  • Low applicability (electric vehicles)
If you are working on live conductors, you can avoid getting shocked by using a pair of these OTC gloves. They are rated 1000 volts which means they can protect you from heavy electrical currents.
CHECK PRICE ON
CHECK PRICE ON
CHECK PRICE ON
pip-gtek-maxi-flex-gloves
The PIP G-TEK wraps up the list of the best top 5 electrician gloves to go for, and it takes the top spot for good reasons too. Its high customer rating on Amazon doesn’t come cheap because the manufacturer must have spent quite sleepless nights on this one. The maximum flex endurance of these gloves also ensures that it is extremely light for easy workmanship and a range of other features should prove why it is the best. Being relatively affordable, the PIP Maxi Flex endurance gloves are designed with a breathable coating, and super light nylon gloves dipped with micro-foam nitrile.
You will find this glove to be water resistant which means there is no risk of getting electrocuted if you work on wet parts. There is added comfort when you wear a pair of this glove not only because it is breathable but also because it is ultra-cool.
Pros
  • Water and light oil repellant
  • Comfortable to wear
  • Super light
  • Enhanced grip and wear due to the dotted palm
  • Durable
  • Wide range of applications
  • The liner has high extensity since it can remain soft after long periods of use
Cons
  • Quite thin
The PIP G-TEK will come in handy in a range of electrical and non-electrical applications. It has a unique design that makes it ideal for the electrical work that lies ahead. You should definitely give it a try.
$28.21
(110)
$24.99
(12)
$111.99
(49)
$16.41
(9)
Ads by Amazon
ilm-safety-gloves
Pros
  • Have a good fit
Cons
  • Fraying fabric
CHECK PRICE ON
CHECK PRICE ON
CHECK PRICE ON
klein-tool-gloves
Pros
Cons
CHECK PRICE ON
CHECK PRICE ON
CHECK PRICE ON
Pros
Cons
CHECK PRICE ON
CHECK PRICE ON
CHECK PRICE ON
otc-electric-gloves
Pros
Cons
CHECK PRICE ON
CHECK PRICE ON
CHECK PRICE ON
Pros
  • Super light
  • Durable
Cons
  • Quite thin
Lovely electricians gloves those are! :D
The OP was a human spammer, link building to his sites.
If any of that is true you're doing it wrong !
RonaldMC,
nicebutdim,
