A dimmer switch isn't a resistor as such and under fault conditions the triac will close allowing fault current to flow.
Ok, I simplified things, but you get my point. You certainly won't get a good Zs!!
Put up some pics please. I've never seen a 30306 CU with integral RCD protection. I'd like to learn...
They are rare but there was a wylex standard range CU with RCD protection.
