Better Odd than a badly installed cable. prone to heat damage due to the badly designed install method tight bends and tight enclosures are not a good idea,
Question, is there actually a need for conduit in this situation, many people just bury the cable as is as long asit's protected by a RCD.
Buried or surface?
It’s surface. It can’t be buried as there is no cavity.
