Here you goThanks I'm asking for link to single core
With Sheath
Without CPC
Available in all wholesalers in Northern Ireland, off the shelf. 1.5mm PVC/PVC Brown, 1.5mm PVC/PVC Blue, 1.5mm PVC/PVC Brown & Earth, 1.5mm PVC/PVC Blue & Earth
With Sheath
Without CPC
To be fair it's only described as meter tails in the sizes normally associated with that use. In the south of Ireland 16mm^2 T&E is described as meter tails because it's often used for that purpose. (Although I use PVC/PVC singles for it.)Still a bit confusing as 6181Y is often named meter tails and thats not what I want
got me thinking so I just did a search I actually can't see any single-core cable for standard circuits i.e 1.5mm or 2.5mm/lighting sockets etc with a sheath and without a CPC ? am I missing something?
Sorry I'm asking 1.5 2.5 etc
With Sheath
Without CPC
obviously it common without sheath and fairly common with sheath and CPC 6241Y
trying to prove singles with sheath don't need a CPC on standard circuits not talking about 16mm+ tails etc.
With Sheath
Without CPC
Yes I do lots of work across the border. At one time it was about 75% of my work. But to be fair I'm only a mile from the border.While your both here, have either of you worked over the border and noticed and differences?
What are some of the more interesting differences?Yes I do lots of work across the border. At one time it was about 75% of my work. But to be fair I'm only a mile from the border.
Yes there are certainly differences (and of course similarities). And different regulatory regimes. And currencies and tax regimes.
I don't use I.S. 201-4 T&E in the north for a number of reasons. One being that it's not made to any British Standard (it is Irish Standard cable). The more important reason being that it is 30% dearer and would make me uncompetitive.What are some of the more interesting differences?
What T&E do you prefer?
I see no reason for Irish T&E not to be compliment with BS7671 but not the other way round so do you use the Irish T&E for jobs in the North?
Twin brown is used throughout Ireland, north and south. It's typically for switch drops or strappers.cool - let me know if you think of any more
I've also heard of twin brown and earth? what this used for?
and is the north mainly TNS?
To help to maintain the DSO's PEN conductor at Earth potential. Obviously the Neutral is connected to Earth at source (which is what makes it Neutral). Earthing the PEN at every installation helps to keep this at Earth potential, plus also the comments on another thread about the dangerous voltages which can present themselves where there is a broken PEN.Sorry stupid question why does the South Require an electrode with TNCS?
ill let you get some Zzzz![]()
