F
ForkEnigma
Currently doing testing on an old building, with concrete walls everywhere, circuit finder dosnt work.
So using 2 way Radios, but they are opening the Protective RCBOs!
Using Motorla, has anybody else had this issue? Does anybody know of a 2 way Radio that will not open the RCBO?
Tia
We use a Mitex radios, never known them to cause any problems with RCBO's.
Thank you, at last a decent reply
[automerge]1594399997[/automerge]
The only reason I can see to use a two way radio is so you don’t have to shout at your mate who’s standing by the DB resetting breakers.
As per the Op, the building is like a Nuclear bunker with 36 inch concrete walls. No DB charts or record drawings. We have accessories that are energised close to existing DBs, but are not fed from there. Its a freaking minefield.
We use Motorola radios, the yellow ip rated ones. Never had an issue with them. What make of RCBO’s are they?
What band and TX power on the radios? Could you select a lower power setting as you're in the same building?
Not sure if practicable for your environment, but if only two of you, possible workaround would be to do some sort of fixed wire comms system between yourselves.
If you both have laptops, could possible set each laptop up with a static IPs and ethernet ‘wonder’ cable connected between them, then run whatever audio/visual software takes your fancy to communicate between laptops.
Not ideal, but may get you out of hole. Modern day version of cups and strings.
Good luck.
Oh my goodness this situation took me back. I used to work in a medium secure psychiatric facility and we had this exact problem. The nursing staff and maintenance staff used radios which I believe were Motorola and every time the buttons were pressed whole rows of Mem (Eaton) rcbo's just tripped out.
They were the pod type rcbo's and it turned out that we had the electronic type and we had to change them to the mechanical type of pod which alleviated the problem completely,costing us thousands of pounds though. Don't think these pods are easily available these days.We were told by our radio people that it was to do with the frequencies but I never fully understood the theories behind it.
I wouldn't imagine this situation would happen very frequently where you have a combination of that type of radio matched to that type of rcbo,just bad luck I suppose.
As others have said a different form of communication is probably the only answer.
Good luck.
Interesting, but don't really have the time.
ForkEnigma,
ForkEnigma,
