B
bgalizio
Looking for help converting T12 fluorescents to LED. Have a bunch of these in my basement and wanted to confirm the correct type of LED tube to get - single or double ended. Each fixture has 4 of the 4 ft T12s and 2 ballasts. Hopefully the pictures help.
[automerge]1595423521[/automerge]
My preference is to remove the ballasts and rewire.
personally i'd fit 2"x2' Led panels and shuffle the tiles around. add additional tiles if necessary.
Yep. Fit led panels, 1200x600, even..... and bin them. I find (or used to before I gave up on them years ago) that the standard with converting is rubbish and with time taken, etc......
View attachment 59624View attachment 59625
Correct, led tubes do not need ballasts, if the input voltage of led tube is AC220V/110V, then just rewire directly.
Thanks! To get my bearings around this, from the set up in the pictures would you recommend wiring as single ended?
That's OK.
Hereby I send a T8 tube Wiring diagram for your reference, simply speaking, LED tube does not need a ballast and starter, you can cut all wires except that from electric box. There are two types of led tube, one is double-ends input, you can connect each wire to each sides. The other is single-end input, you can connect two wires to the 2 pins of the input side(Import: first of all, you shall confirm with the Tube supplier which end to be put).
Take it easy, not difficult, but take good care.
