Eh up
Is it possible to cut a neat notch - say arch shaped, with the arch diameter about 25mm - in a stainless steel cooker hood chimney, without either making a mess of the chimney, or breaking/burning out tools, or both?
Special hole saw - or maybe regular holesaw used for steel - and cutting compound, on low speed? Jigsaw for the straight bits - is there a special blade? Speed setting? Compound? Clamp the steel either side with offcuts of timber, or it doesn't bend/flap about too much?
There will be 20mm galv conduit running horizontally behind the chimney (which recirculates filtered air back to the room, so a small gap around the conduit will be fine).
Advice on good cutting techniques appreciated.
Cheers!
Cheers!
