That is an interesting point!
Regulation 462.1 requires an installation to a means of isolation, and I would assume that has to be accessible by the owner or occupier of the installed location. Not being able to isolate the supply if an obvious fault is detected (or simply for any repair work) is looking like C2 territory to me.
Ladies and gentlemen, discuss...
Yea see thats what I thought... it has to have the isolation, but doesn't say it has to be accessible... its just adequate accessibility at the unit not getting to the unit... but surely if you can't access it then you can't isolate so does it class as isolation if you can't physically do it ?
I dont get "phased" easily with these jobs i like to get them done properly and sleep at night knowing that its safe. Id be worrying that if I turned it down then he will get diy dave sto sign it off
[automerge]1596143314[/automerge]
Ok what calculations are you thinking of doing? Maybe we can help you check them.
Im quite capable dont worry but as of today in not sure whether I'm going to need too because I now don't know what the landlord wants to do
i was under the impression that if it has been calculated previously to 25mm for example (I haven't seen the actual size of tails yet) then the chances are it would need increasing in size
I agree with you if they don't want to move it into the flat then turn it down.
I assume location of consumer unit would be a c3??
Why would it need increasing in size? I would say the chances are that it doesn't need increasing in size, in fact I would say there is a very high chance that if you do the calculations correctly the flat would need a smaller supply and cable size th a 25mm.
I did not say that if they don't want to move it I wouldn't do the job. I said that it should be accessible to the flat and if the customer refuses to address this issue I would refuse the job. Giving the flat a key to gain access would be addressing the issue.
Don't assume codes. Location of the consumer unit wouldn't be any code as far as I am concerned.
[automerge]1596144308[/automerge]
How often have you ever seen 35mm2 cable in a domestic property, let alone a 1 bedroom flat?!
Not very often, but that is completely irrelevant. It doesn't matter how many times you have seen a particular cable size in an installation before, that doesn't have any bearing on the calculations.
I specified a 2x 95mm in parallel for a 100A supply not very long ago, I'd never seen that before but it was what I had calculated.
What about access to it?
Regulation 462.1 requires an installation to a means of isolation. I would argue that an "installation" would be within the extent of ownership/occupation, so somehow that has to be in an area that the flat occupier has legal physical access to at any time necessary, otherwise it is a safety issue.
[automerge]1596145405[/automerge]
Of course I am assuming in the OP's statement:
I eventually found out that it is in the cellar below the shop next door.
That access to this cellar is not provided or guaranteed to the flat occupier. I may be wrong, but that would be a rather odd arrangement from the point of view of the shop owner/occupier!
[automerge]1596145557[/automerge]
I wonder if the IET will introduce a CU sticker with "Beware of the leopard" for this sort of situation?
Again what annoys me on here is that people don't read all the replies what I said was that the 25mm was an example ffs i haven't done anything yet what I said was IF they were 25mm IF that means they have a reason to be that size and would of been calculated as such so theoretically without actually calculating anything you would initially think cablw size would go up... again not calculated anything yet... and ill say it again I have not calculated anything yet.
What was your reasoning for 95mm cables on a 100A fuse? I can't even think of a situation where that is necessary... might help me in the future if I come across a similar situation... i also wasnt assuming codes. 1 the tennant will not be allowed a key to the shop... thats ridiculous therefore would it make the code c2 or c3? as you would have no means of isolation without access to the shop which isnt always going to happen... i think there's alot of grey area here and that's the problem
Regardless of the Regs, common sense dictates that there should be a means of isolation in the flat at the very least. Say, if it was midnight on Saturday and the shower catches fire how are the electrics isolated? Put that question to the landlord?
It would obviously make sense to have isolation in the flat, but common sense and electrical regs don't always go together as we know.
In your shower situation, hopefully the shower would have an isolator (as required by regs) - Hopefully that isn't in the cellar too! :oops: .
If the property is sold separately to the shop though in the future, the CU might become impossible to access so obviously that is an issue that really should be addressed, though which regulation it would fall under might be an interesting discussion.
Might be more sensible to get the landlord to contact the DNO and see if the service head can be moved into the flat? Though I doubt they'd do that FOC.
What if it was the shower switch though?
Shower catches fire, get out don't worry about isolation. It isn't ideal but I don't see a problem.
Seems like everyone is in the same boat as me... not 100% sure lol
I'm going to advise him to move the consimer unit up to the flat that way at least it can be accessed by the occupant.
See what happens because this is obviously the more expensive option but the better one in my opinion
Thanks everyone
Have a look at the memorandum of guidance on the electricity at work regulations. Regulation 12 requires a means of cutting off the supply. Paragraph 187 of the memorandum requires it to be in a suitable location.
Does that apply to dwellings.
The problem with wiring regulations, etc, is they tend not to be written assuming the most advanced muppetery possible. Same for the EICR codes, they cover what is typically seen but not everything.
As mentioned, here is the HSE guidance:
Pages 33-35 cover this in sufficient detail to allow a C2 code backed up not only by the IET regulations (which are not statutory), but the also by the Electricity at Work Regulations 1989 (which really are "the law").
Does that apply to a dwelling.
NellyManjaro,
davesparks,
