Good afternoon.
I'm fitting a new kitchen with a new hob and oven. I hope to use just 1 isolation switch for both appliances. Together the wattage size is almost 11kW.
Do I need 10mm cable with a 50A MCB?
Is that right?
Thanks.
nope. you need a 6mm cable on a 32A breaker, 45A cooker switch, dual outlet to both appliances.
Great thanks.
The appliances are a Neff N70 hob and Neff N70 oven.
Does the manufacturer specify anything, other than the norm 'consult a qualified electrician'?
From my quick googling, it would be ok, as long as the cooker control doesn't have a socket outlets. Its 9.3kW for the hob, 3.45kW for the oven?
UK
Cable and MCB size for oven and hob
Philip George,
Philip George,
