K
kotecha101
Good Morning ALL
I have a terraced house and let out . Novice Landlard and come across to this site/ forum Many Thanks and informative,
have had two FI several C2 & C3 But no C1.
F1 as cause Meter tails are 16mm . this is the cables between the meter and the consumer box.
I also have two 16mm cables just before the meter reading and I understand that these are installed by the co supplying the power to property. both the metr and the consumer unit box are 6/9 inches apart. Located in cupboard inside as terraced house.
when questioned the Electric Engineers (EE) says that its not your lookout - Find it weird as he was on about safety of tenant etc. / insurances etc.
The report requires 25mm .
Another confusing issue is; Has given an overall summary 'UNSATISFACTORY' but than in recomendations in Sec 6 as has put subject to remedial action taken / Further Investigations tested in 3 years or change of tenancy.
Amother issue was the Consumer Box Changed by another EE 4 years ago and Building Regulations Certificate of Compliance held. This EE mentions that the consumer unit is a cheap version should be replace, though the Guy who did it 4 years ago is a listed and approved trader person with NICEIC
Questions:
1. Is this still safe for tenants to continue living there and remedial actions taken
2. what are your thoughts ?
Regards and many thanks
PK
Questions:
PK
