Thanks everyone for the replies. I'll take everything out tomorrow and see what happens.
It hasn't happened for a couple of months now, usually goes straight back on.
RCD. The downstairs circuits are all on the same rcd. Keeps tripping if I try to flip it up, turn the kitchen off and ilts fine
Something on your RFC is causing tripping try unplugging things and gradually turn them back on till the RCD trips ergo there is your problem
if appliances are on a FCU and the FCU is only single pole switcthing, could be a N-E fault on an appliance.
AFAIK all BS1363 FCUs are DP although that doesn't stop someone making up SP arrangements using grid parts.
i was thinking of the older FCUs that a lot were only single pole.
Been fine all day today. Had dishwasher, washing machine all on at the same time. Rains stopped aswel ?. I'll have to see it it happens again next time it pi$$es down. Cant go unplugging appliances and fault finding when everythings working. Thanks for everyones ideas.
You could eliminate some of the appliances by plugging them in to an extension lead from another circuit? Maybe kettle toaster etc. One at a time though and make sure the lead is fully unwound.
