K
ktnwin
I have an outlet outdoor, supported straight up by a galvanized pipe. It has only black and white wires, no ground. The galvanized pipe is extremely rusted and breaks exposing wires inside the pipe !!! On top of that, it has no electricity either.
Please note my home is ~40 yrs old.
I tracked it down this outlet (and pipe) comes from an exterior junction box in front of my garage which contains wires without electricity. For some reason, there is no electricity going into this box. I know the Romex cable that is supposed to carry electricity here but it could have been cut on the attic.
So I disconnect the connection to this outlet from the junction box, and the pipe going in this box. the pipe now contains 2 wires that serve nothing with a large part underground. The outlet has been cut off and removed from the pipe.
Here is my question: do I have to remove the unused pipe of the ground ? OR I can just leave it there.
I appreciate any advise on this.
More info: the junction outside my garage uses to feed some lights in the front yard landscape. These lights are no longer used and replaced by solar charged LED lights. This box is useless for me.
Question: should I remove this box or just leave it there ?
