O
ObviousDecoy
Hi,
I had what I thought was a licensed electrician extend electrics from an outlet to the opposite wall for lights in a wardrobe I'm having installed. The wardrobe builder requested a fixed spur on the wall and the cable to to be run under the floor boards.
However, the electrician ran the wire under the skirting board which are removed as I'm having a floor installed.
I was concerned and researched a bit on safe zones which said you aren't supposed to put wiring behind or under skirting boards. However he insists because the wire is behind a 3A breaker that safe zones don't apply.
Can anyone tell me if that is legal or not?
