Ideally no, but if that’s the only option there’s no reason why not
But its against the regs
Because of the zoning?But its against the regs
Ok agree.., but if the sockets were in the Zone ie: in the skirting that would be ok, it would be no different from installing skirting dado.
Obviously the sparky will have to decide the best method to hide his cabling.
It needs to be obvious to other people that it would be a zone, so any socket, switch, spur, blanking plate as a reference.Does a 1G or 2G blanking plate create a safe zone?
Does it have to have wiring or even a box behind it?
Unless installed in metal conduitBehind a skirting board is against regs.
I often created safe zones by installing a wired socket. Not to sure about a blank plate on its own. In practice would work but strictly speaking does, nt qualify in my viewDoes a 1G or 2G blanking plate create a safe zone?
You could write a warning message on the inside of the blanking plate!I agree. Anyone looking behind the cover plate would see no cables and probably not realise it was there to indicate a zone.
