As @nicebutdim says, you will probably get them from another wholesale outlet for quite bit less then CEF.
Here is the interesting bit. Just out of curiosity I rang CEF this morning (ROI). He quoted me 1.50 euro for a double box. I then looked up a number of wholesalers in N. I., assuming they would be readily available, but no.Looked up Screwfix. They don, t stock them. I always assumed pvc flush boxes were a UK product exported to ROI. But no.They appear to be an ROI product that's little used elsewhere
I wish I'd known about these a few years back but, since first being made aware of their existence, they're firmly imprinted in my mind. Not sure I see price being much of a problem, unless you were planning to use them on every job, but for an occasional damp wall a couple of extra £ is of no consequence.
A quick google search of the part number doesn't turn up many results, but CEF & Rexel appeared, so they're probably also stocked by other wholesalers who don't worry so much about having an online presence. Given the lack of Irish results, there's a good chance of the same situation in IE.
MT is a British manufacturer, distributed in IE by Core Electric, so it's likely they are exported from UK to IE. Are PVC flush boxes commonly used in IE? The reason I ask is an old job lot of 16mm 1G PVC boxes I have lying somewhere, which were made by an Irish company.
Any wholesaler that gets Marshall Tufflex items can get them, you might just need to wait a little till they put an order in as they aren't a readily stocked item. I got them from my independent wholesalers last time I needed them, they are handy when doing old houses with no cavity walls as they won't rot the same way galv boxes do. Just don't set them with bonding in that setting, that's a total no no.
Pvc flush boxes very common. But 16mm size less common as, its too shallow for dimmer . Still used.
These would be quite an age. No use to man nor beast these days, but I'd never seen PVC surface boxes from that era. Pretty sure 'Tyrconnell' was somewhere on the packaging and I note that Core Electric are based on the Tyrconnell road in Dublin. Quite possible those old boxes were also made by MT.
Meant to mention earlier that CEF list prices in the UK aren't generally regarded as reasonable, so pay no heed to the price on my link.
