Galv steel is an awkward surface to paint, not much takes readily to it. IIRC you have to use something called mordant solution before primingJust a thought could you not red oxide the metal boxes before you install them.
As @nicebutdim says, you will probably get them from another wholesale outlet for quite bit less then CEF.Great box. But horrendous price.Can appreciate the reluctance to use plastic
Here is the interesting bit. Just out of curiosity I rang CEF this morning (ROI). He quoted me 1.50 euro for a double box. I then looked up a number of wholesalers in N. I., assuming they would be readily available, but no.Looked up Screwfix. They don, t stock them. I always assumed pvc flush boxes were a UK product exported to ROI. But no.They appear to be an ROI product that's little used elsewhereAs @nicebutdim says, you will probably get them from another wholesale outlet for quite bit less then CEF.
Pvc flush boxes very common. But 16mm size less common as, its too shallow for dimmer . Still used.A quick google search of the part number doesn't turn up many results, but CEF & Rexel appeared, so they're probably also stocked by other wholesalers who don't worry so much about having an online presence. Given the lack of Irish results, there's a good chance of the same situation in IE.
MT is a British manufacturer, distributed in IE by Core Electric, so it's likely they are exported from UK to IE. Are PVC flush boxes commonly used in IE? The reason I ask is an old job lot of 16mm 1G PVC boxes I have lying somewhere, which were made by an Irish company.
