T
tvrulesme
Replacing some back boxes in a room which is due to be plastered with Lime plaster.
Galvanised steel is known to slowly react to lime and in fact the boxes I am replacing have rusted badly so considering using plastic dry lining boxes instead of galvanised.
Is there anything in the regulations which would advise against this? It's for a kitchen if that makes any difference?
Yea, you can get them. Just the same as metal boxes, but in plastic.
Nothing against them in regs. No difference than any plastic surface box
Don't use dry lining boxes though, that would be a bit shoddy. Use plastic flush boxes...Marshall Tufflex make them
Reactions: nicebutdim
As above all good to go ahead with plastic
The only slight downside with plastic boxes is price. Otherwise its all uphill.
  • Agree
I work out in a lot of rural properties here lime plaster is common, I've never found a corroded box in lime unless the wall is damp
There was a lot of damp but I'd rather be safe than chance it.
From my searches:
"Lime attacks steel and galvanisation is only a thin coat of zinc over the top of mild steel, so any slight removal of this protective covering will allow the moisture in the render to rust the steel. The galvanised steel will also slowly react with lime and this will cause the structure to fail as the rust expands and cracks the render."
just use plastic surface boxes sunk in.. virtually the same but a fraction of the cost.
  • Disagree
Reactions: 123
Good luck with that, they are anything but the same as there is no forgiveness if you set a surface box into the wall. The faceplate has no overlap so the box has to be set perfect, and the plasterer has to work to that the same way they would with a door frame.
I, m inclined to agree with that assessment. Could see a lot of headaches arising from it.
Reactions: DPG
Just a thought could you not red oxide the metal boxes before you install them.
Galv steel is an awkward surface to paint, not much takes readily to it. IIRC you have to use something called mordant solution before priming
As @nicebutdim says, you will probably get them from another wholesale outlet for quite bit less then CEF.
Here is the interesting bit. Just out of curiosity I rang CEF this morning (ROI). He quoted me 1.50 euro for a double box. I then looked up a number of wholesalers in N. I., assuming they would be readily available, but no.Looked up Screwfix. They don, t stock them. I always assumed pvc flush boxes were a UK product exported to ROI. But no.They appear to be an ROI product that's little used elsewhere
I wish I'd known about these a few years back but, since first being made aware of their existence, they're firmly imprinted in my mind. Not sure I see price being much of a problem, unless you were planning to use them on every job, but for an occasional damp wall a couple of extra £ is of no consequence.
  • Agree
Reactions: 7029 dave
Email
Time zone
Last seen
Plastic back boxes for lime plaster
tvrulesme,
pc1966,
