I know this has been brought up before but as a QS for a housing association ,i have been asked my opinion on interpretation of the regulations concerning SPD with smoke alarms (assuming they are a safety service).
several scenarios exist here :
1. Upgrading or updating existing alarms (ie
ut of date or wrong type)
2. Upgrading installations to LD2 (mostly adding a optical smoke ) usually in the lounge (hallways,landings and a heat in kitchen is the state of most of our properties).
3. New installations on existing property’s (usually from lighting circuit ) with radiolink
4. A full fire panel install in a HMO.
Probably the best and safest option is to install but this could require a Consumer Unit change or isolator with SPD which will involve the DNO (long delays usually).
does anyone have any ideas or opinions regarding this?
ut of date or wrong type)2. Upgrading installations to LD2 (mostly adding a optical smoke ) usually in the lounge (hallways,landings and a heat in kitchen is the state of most of our properties).
