Probably, they have us for everything else.I assume there will be a fee involved in notification?
You will be resuscitating all sorts of little nasties including dead skinIt's not shower water it's condensed water from the shower extract steam.
Surely not MikeI'v ducted the shower ceiling fan into the top of the cold water tank, seems a waste to vent it to air through the roof.
One thing good to come out of this is someone will know what to get mike for Christmas next year.Surely not Mike
Do you mean that dead skin you breath in all night in the bedroom after exfoliating your body by undressing in the room.You will be resuscitating all sorts of little nasties including dead skin![]()
And because of this, you think It's OK to add to it ?.My take on all of this, is that it is a shower fan and the condensed water that goes into the water tank is probably less contaminated than the water supply into it, we have private water main over a mile long, run in metal barrel and whenever the water board work on the six inch fire main beyond our supply the water is very brown for some time and I have to clean all the cistern inlet valves, such is living in a rural environment.
My New Year’s resolution is to try not to get into arguments especially ones that are pointless.Wow that really is clutching at straws to prove you premies that I am doing something wrong, as you do to most of my posts, even at one point you put a follow tag on my posts so you could comment even more, then denied it, the proof of the pudding so to speak is that its been in this configuration for over thirty years and no roof problems have ever been encountered, no mound, no condensation and no infestation, can you say the same for something you have installed has lasted that long without a problem?
No it’s notMy New Year’s resolution is to try not to get into arguments especially ones that are pointless.
Jobs a good un Mike![]()
I knowNo it’s not
I'm not sure you comments are genuine or if your joking so apologies if I suck the fun out of it. Bylaw 30 used to cover header tanks but that was replaced by the water fitting regulations in 1999. A fitting lid is a feature of bylaw 30 kits, it's to stop ingress and excessive water vapour escape. As a novel idea/approach I see it's actually quite a clever idea, perhaps only for grey water though.Wow that really is clutching at straws to prove you premies that I am doing something wrong, as you do to most of my posts, even at one point you put a follow tag on my posts so you could comment even more, then denied it, the proof of the pudding so to speak is that its been in this configuration for over thirty years and no roof problems have ever been encountered, no mound, no condensation and no infestation, can you say the same for something you have installed has lasted that long without a problem?
