Not going too off topic but technically now you mention it an unfused supply off a ring? maybe theres a reg being broken there.
If you are talking about USB 13A sockets, since 2016 when the socket British Standard was revised to cover built-in electronics, the design has to incorporate a fusible link or fuse, and the psu must be SELV, meeting creepage and clearance distances and transformer insulation requirements etc. etc.
USBs got off to a bad start before that revised standard, when the market was flooded with dubious products, though I think China also makes 'proper' ones now.
But these days I like to think if you buy an approved product from a reputable manufacturer/source, there should no longer be a problem!
Newer technology allows a phone or tablet you plug in to negotiate with the USB charger what voltage/ current it wants.
I guess you could say that's that's an added safety feature, or something else to go wrong!
I'd be interested to know if these sockets do have a fused link or fuse.
But really I'm only referring to Rings etc Even if you took a selv spur of a Ring you have to fuse it.
Fused plugs are only required in the UK where we use Rings.
the flex is protected by the Fuse/MCB at the DB on a radial.
Only in specific cases where MCB and cable are specified together to meet adiabatic limit, etc.
That is why they often have thicker cables and limits on MCB for non-UK systems. We now also have thicker more expensive cables on most equipment because no one makes just for the UK market any more!
The collar/spacer thing worked great. This forum always has the best advice.
The only thing, I bought some longer screws from a well know distributors and they basically stripped the thread of the backbox. Where do you buy 3.5 screws?
