B
Baz1974
First post so go easy on me.
i am a competent DIY’er, just after some advice. Apologise if the terminology isn’t spot on!
my house was rewired two years ago, a loft light was put in, but I need an additional light in there as I use it for lots of storage. I’ve looked at adding an extra light off the ceiling rose, but when researching the wiring all I’ve seen shows a switch wire and a supply wire going into the existing rose (with another cable going out to the next rose).
I’ve only got one cable going into my rose (from the switch) is this the switch/supply? I’ve attached pics of the rose and the switch if that helps.
