I'd contend that any visual inspection would need to cover 100% of the cable.
That's impossible with VIR as its in conduit, and if it isn't in conduit then that a whole other problem as it is single insulated cable.
Obviously if it was an insulated and sheathed rubber cable like TRS or CTS then that may be possible to do 100% inspection.
If it was VIR in metal conduit I would be far less worried as fire risk fairly well contained.That's impossible with VIR as its in conduit, and if it isn't in conduit then that a whole other problem as it is single insulated cable.
This type of cable has been installed domestically as far back as the early 1900's, so well over 100years old its done its job.
