Discuss Liquidtight non-metallic flexible conduit. in the DIY Electrical Advice area at ElectriciansForums.net
wyciwug
Hello
can this conduit be used in crawlspace, under the deck outside, and outside running along siding? Will it fail inspection?
Hello
Yes it’s legal and it’s outdoor approved by secure it every 3 feet.
Thanks, passed rough in first time. Final failed due to missing ground rod. Complete soon.
You need to drive 2 ground rods at least 6 feet apart and bond your panel. Good luck
Reply to Liquidtight non-metallic flexible conduit. in the DIY Electrical Advice area at ElectriciansForums.net
I received multiple quotes to install a long run for my electrical outlet NEMA 14-50 for my tesla. The cost is huge $1800 give and take...
Hello, I am burying a fiber optic cable so I have internet in my garage. I have purchased the following flexible conduit to run the fiber optic...
Hi, folks.' I have a carrier 38MGRQ48E '5 zone' mini split system with 4 'heads'/evaporators installed, and one 'channel' still open. Had it...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
I need to run a electric wire from the garage to outside against the house and back into the kitchen for a stove can I just use a outdoor wire and...
