This isn't very electrical, but never mind!
I'm adding an extractor fan to a bathroom in a 4th floor flat.
The builder has helpfully cored a hole for me (110mm)
In the past I've used the Manrose Internal fit wall kit which works brilliantly IF you know in advance and core a 117mm hole.
www.screwfix.com
In this case there's already an 110mm hole. Ever the optimist I tried one anyway and there is no way on earth it's going through.
Getting to the point, has anyone tried the Xpelair version as it looks to use a normal 4 inch duct pipe plus a folding vent and it would seem to have a much greater chance of working in this situation?
Are there any other products worth knowing about for this situation?
TIA
Manrose Internal Fit Wall Kit with Backdraft Shutter 117mm - Screwfix
Order online at Screwfix.com. Internal fit wall kit is designed to simplify installation by allowing the user to fully fit inside the building, avoiding the need for scaffolding and significantly reducing the cost and complexity associated with working from heights. Includes backdraft shutter...
Simply Silent Easy-Fit Square Wall Kit White
Complete installation without stepping outside
www.cef.co.uk
TIA
