Relating to this discussion I saw this today:
www.beama.org.uk
Basically it says if they are marked line/load or have direction arrows they are not suitable, which seems to rule out the Wylex compact RCBO as they have direction arrows on them.
Electrium / Wylex / Crabtree now have a declaration of conformity that states that their single module compact RCBOs are bi-directional:
Direct link to PDF:
https://docs.electrium.co.uk/Documents/NHXS1B06_Declaration of Conformity Bidirectional RCBOs.pdf
Link to web page (for B6 Wylex RCBO) which has a link to the above PDF, if the link above doesn't work directly
Just for good measure, a couple of screenshots of the document:
Hager seem to do bidirectional RCBO (Type A RCD) with C-curve overcurrent, e.g. ADC932R... unlike their single pole solid neutral B-curve ones (e.g. ADA332G, which they do not state as bidirectional) the C-curve ones are 2P. I've never seen one in the wild, though.
There is a vague reference to a Fusebox bi-directional RCBO "coming in 2024" from one of the online wholesalers who sell their stuff, but I've not heard anything else.
For those interest in the issues about bi-directional/uni-directional devices, eFixx did a bit (involving a whiteboard!) about 1 hour 29 seconds into this video:
Suspect the upcoming draft for public consultation (8 May - 5 June 2024) is all about this:
https://electrical.----------/bs-7671/updates-to-18th-edition/ (the forum blanks out part of the address, you'll need to replace the dashes with "the iet" without the space)
Hope the above is useful!
