Dec 21, 2022
212
Yorkshire
Trainee Electrician
I've got myself a MFT1720.
Sadly it doesn't have any batteries in it.
Which batteries go in it ? So I can buy some. Can it be any rechargeable batteries?
I believe it is standard non rechargeable AA batteries in that line of MFT. Take the cover off and have a look, usually that sort of information is stamped into the battery holder.
Reactions: shocksl
My 1720 takes 6 AA Alkaline or niMH, same as all 1700 series apparently
Reactions: shocksl
I saw this to. I've seen certain outlets selling NiMH for 44 quid or so!
Then I've seen amazon brand ones for like a fiver. Iol. Not sure if I should get the cheaper ones lol Don't know if there's a difference lol
Deleted (wrong price).
Reactions: shocksl
Is this a wind up or posted in earnest?
Inside of any battery cover provides details of battery type and quantity required.
£44????? Are they gold plated and come with a brass pig? Screwfix are £9 for 4 2100mAh AA Varta. £18 for 2 packs and 2 left over for your torch.
Reactions: shocksl
That's normally the case, but not with the 1700's it seems.
The only clue is the available space.
Certainly not cheap for six rechargeable AA batteries. I like Eneloop (standard white ones) - there are cheaper options again, but Eneloop have proven very reliable and so I stick with tried, tested and trusted.
Reactions: shocksl
Hi Thanks
Yes the kit didn't have any mention of the battery that is required.
As its expensive I didn't want to just put any ol battery in there and mess the kit up . It's already too expensive lol. Especially for a L2 guy 😆
Yup, good as long as you have a good supplier. I read somewhere that theres a lot of fakes about.
nubattery.co.uk (formerly 18650.com)
Been buying from them for years as reliability was often critical. I wouldn't hesitate to recommend them.
Reactions: Fazz711
The Panasonic Eneloop Nimh batteries have a much lower self diss-charge rate than other Nimh's, I think it's somewhere about 10% in a year, more convenient when your equipment only gets intermittent use.
Reactions: nicebutdim
From post eight it looks like six AA cells the middle two being below the outer cells on either side.
I've replaced my Mfts 6 AA batteries with lithium-ion ones.
Yorkshire
Trainee Electrician
MFT1720 missing batteries.
Electrical Tools and Products
shocksl,
mainline,
