barisk DIY Mar 28, 2024 #1 Hi , I’m going install a commercial 450mm extractor fan , what size and type of cable should i use ? Last edited by a moderator: Mar 28, 2024
D DPG ~ Broke Internet Esteemed Arms Patron Mar 28, 2024 #2 Surely that's going to come down to rating of fan, length of run, install method etc?
C Cbelectrics Mar 28, 2024 #3 Need to know more than the information provided and if you don’t already know not sure you should be installing it in the first place. As the above reply said, need the type of system installed back to the dno/fan power rating/distance between ccu and fan etc
westward10 ~ Staff member Admin Esteemed Supporter Mar 28, 2024 #5 From the capacitors I would guess single phase.
D davesparks Mar 28, 2024 #6 Mikegh said: Possibly 3P that isn't it ? Not too familiar with them Click to expand... Pretty unlikely to be TP with capacitors on it
barisk DIY Mar 29, 2024 #8 It’s a single phase 1500w motor. It has a 6 amps speed controller, distance from controller to fan about 3-4 meters .
