barisk
uk
Hi , I’m going install a commercial 450mm extractor fan , what size and type of cable should i use ?
Surely that's going to come down to rating of fan, length of run, install method etc?
  • Agree
Reactions: SparkyChick
Need to know more than the information provided and if you don’t already know not sure you should be installing it in the first place.
As the above reply said, need the type of system installed back to the dno/fan power rating/distance between ccu and fan etc
Reactions: Fazz711 and DPG
Possibly 3P that isn't it ? Not too familiar with them
From the capacitors I would guess single phase.
  • Agree
Reactions: James and Mikegh
It’s a single phase 1500w motor. It has a 6 amps speed controller, distance from controller to fan about 3-4 meters .
barisk
uk
Cable size for commercial extraction fan
barisk,
barisk,
