littlespark
Staff member
Supporter
Patron
My friend has got one of those robot lawnmowers that automatically goes out once a day and runs around the grass.
There is a single core guide wire buried around the perimeter of the lawn that must carry a signal that the mower senses and knows not to cross…
This wire has a break in it somewhere.
Is there an easy trick, or tool that can be used to find out how far along the wire the break is…. Or is it likely non repairable and needs replaced?
He’s already tried a continuity test with a simple multimeter, which showed an open circuit between the two ends…. But that might just be the lack of capability of a simple meter.
I could shove main voltage down it and see where the grass burns??? 🤔⚡️
I seem to remember Lucien describing a method he used that involved sending a signal down the cable and measuring the reflection that came back from the break. Something to do with using a CRT monitor to show the timing difference between the two and then calculating the distance to the break.
Time to pop to Radio Rentals for a 14" CRT...
got my old childhood one in the attic, actually. Why ive carried it through 5 house moves in the last 30 years, i'll never know
Here it is:
It's lovely that all these gems of wisdom are preserved here :)
Send your wife to guide a proper mower round the lawn?
Tin hat on!
Seriously, use a cable tracer and follow the cable 'til it loses signal...
Use an AM radio.
I thought i would update this thread, as ive been asked to fix another one.
The AM radio trick didnt work at all.... I ended up cutting the wire myself and testing continuity on each half.... splitting it again and again until i found a break.
Through crimp to repair as i went...
This new job is a much bigger patch of grass.... and i dont like chopping perfectly good cable...
So this time, i might try the water divining trick.... see if it works.
Two bent pieces of fence wire held loosely in my hands... they turn towards each other when over water... it might be the same with an extra low voltage.
You'd think those pesky robots could distinguish between a wire and a blade of grass!!
Upgrade to a GPS unit to save that hassle of a broken wire!
Ok. Much easier fix this time. Not the guide wire at all, but the 28V power supply.
It’s tripping the mcb without the mower charger being plugged into it.
Now to source a replacement….
