littlespark
Staff member
Supporter
Patron
Aug 12, 2017
14,337
20,736
3,557,381
51
Scottish Borders
My friend has got one of those robot lawnmowers that automatically goes out once a day and runs around the grass.
There is a single core guide wire buried around the perimeter of the lawn that must carry a signal that the mower senses and knows not to cross…
This wire has a break in it somewhere.
Is there an easy trick, or tool that can be used to find out how far along the wire the break is…. Or is it likely non repairable and needs replaced?
He’s already tried a continuity test with a simple multimeter, which showed an open circuit between the two ends…. But that might just be the lack of capability of a simple meter.
I could shove main voltage down it and see where the grass burns??? 🤔⚡
If you have one of those circuit tracers / fuse finder things you could attach it to one and and a spike in the soil and see what the probe finds as you go round?
I seem to remember Lucien describing a method he used that involved sending a signal down the cable and measuring the reflection that came back from the break. Something to do with using a CRT monitor to show the timing difference between the two and then calculating the distance to the break.
Time to pop to Radio Rentals for a 14" CRT...
Reactions: SparkySy and DPG
got my old childhood one in the attic, actually. Why ive carried it through 5 house moves in the last 30 years, i'll never know
  • Funny
Reactions: Jim_e_Jib
Here it is:
It's lovely that all these gems of wisdom are preserved here :)
Send your wife to guide a proper mower round the lawn?
Tin hat on!
Seriously, use a cable tracer and follow the cable 'til it loses signal...
Use an AM radio.
Use an AM radio.
Im going to give this a go. Seems straightforward enough.
Then I’ll look for the other video she mentions at the end on how to repair.
I was thinking through crimp
Reactions: DPG and Jim_e_Jib
littlespark
Staff member
Supporter
Patron
Scottish Borders
Robot lawnmower guide wire repair
littlespark,
littlespark,
