M
manos
Hi everyone,
I am an industrial Electrical Engineer and I need some help of which is the best method of connecting IP66 outlet sockets in the garden area.
The power will be taken from a Ring socket inside house using an FCU 13A. The FCU can be outside or inside. If outside, it will be IP66.
As you can see from the diagram there are two lines, a red one and a black one of how to connect sockets (as Radial).
The cable to the FCU from existing socket will be twin and earth 2.5mm and from FCU to IP66 connection box the same.
From the connection box the cable/s will be twin and earth 2.5mm armoured cable.
Which one do you think is the best method of connection. Any comments appreciated.
