Apr 15, 2023
London
Hi there
I have been on a job to fix intruder alarm.
Alarm Texecom 1995 very old alarm .
Owner 96 years oldman wanted to replace battery inside the panel. Unfortunately when he took cover down battery fell pulling other cables from terminals. I’ve managed to terminate cables back as I thought they need to be. Now I need help with the siren outside + small siren near the panel. How do I connect them . Obviously siren + and - tamper but terminals are different in this old panel . Can someone who done such an old panel help me? Look on the picture terminals for sounder S,D,C,B,A I think. The small siren with wings like a fan. Thanks for any advise.
Does this help or do you need more help
Reactions: James
Hi thanks for that , why on the panel I am working on the terminals C and D are linked together. Is that ok? Which terminal should I use for that old style additionall siren under the panel ? Thank you
D is the negative for the SAB hold off supply
In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C in the panel which is the tamper return
C & D are linked in the panel to stop a tamper being indicated so you need to check the external sounder has a correctly connected SAB
London
Old intruder alarm
Kinxsize,
UNG,
