- Jul 4, 2023
- 28
- 19
- 33
- United Kingdom
- Electrical Engineer (Qualified)
Morning all,
Little advice regarding whether spuring from a Three phase isolator to a single phase FCU is allowed?
I need to wire a Single phase FCU which is located right next to a 16A TP isolator to a high speed door. Obviously, It would be a lot less pain to wire straight from the TP isolator to a SP FCU. Rather than running a cable from the Sub main for the FCU.
Anyone have any objections? I know it's not ideal. However, via a regulations point of view I can't find anything against this practice.
Cheers.
Cheers.
