IAmSparkytus!
485
354
101,238
Newcastle Upon Tyne
Hello
Is there an electric torque screwdriver on the market which can be used to tighten MCB terminals etc?
Cant find one which can be set at say 2.5Nm and the click when torqued to that setting.
Not calibrated but worth a look.
I've got a couple of these, found them to be hard to beat for the price.
That last one is the one I have but it doesn’t click when it reaches the max of the level you put it on, and you can’t choose a specific Nm setting
Don’t think this one disengages either when it reaches the desired torque
The online video's show the motor stops when the set torque is reached.
The rotating collar for changing torque clicks into the various settings, but the torque is not indicated (other than by the thickness of a line), so the values would have to be established by experiment, or a torque gauge!
Looks neat.
Looks neat.
Hmm the videos I watched earlier didn’t show the motor disengaging. Can you send a link please?
I think it only goes up in increments of 1nM. Wonder how much difference 0.5nM makes or how many turns of a screw that would count for for example.
Think the SPD I was working with today said 2.5nM - would 3nM make that much difference?
This was the first of some I watched, but I've just noticed (which I hadn't before 🫢) that the screwdriver gets set on the screwdriver setting, not a torque setting, so I think I'm wrong! Apologies
But not sure what you mean by 'disengages', I'm sure the screwdriver will stop turning when the target torque is reached, usually achieved by a clutch slipping.
View: https://www.youtube.com/watch?v=WB_XdVGaCiA
I doubt any of the above devices will have any calibration certificate for their torque settings or have any approval from the manufacturer to be used as a precision torque device so wouldn't be any use for torqueing up terminal screws.
Reactions: DPG and Avo Mk8
that depends on the tolerance that the manufacturer has allowed in their torque spec, if they allow a tolerance of +20% then 3nM would be fine, assuming that the torque driver used is very accurately calibrated and not already operating at some tolerance above the set value.
A Newton is 100 grams (on earth).
I was told an easy way to think of 1Nm torque, is it's a small apple (100g) held at 1 metre distance..
0.5 Nm is 50 grams at 1 metre. You wont turn a screw much more by adding that!
I've just got a Wera 1.2 - 3 Nm manual driver, calibrated. Perfectly serviceable for what I need.
The original Bosch go (push to activate) had an electronic torque.
The Bosch go 2 has a mechanical torque and also had a button as well as push to start.
The Bosch 3 I think is a bit more accurate.
The mechanical torque is far better for consumer units, but obviously isn't going to be as good as a proper torque screwdriver.
Newcastle Upon Tyne
Electric Torque Screwdriver
Electrical Tools and Products
IAmSparkytus!,
mainline,
