I have a Hafco al 340 lathe the old 2kw motor carked. I bought a 3hp motor to replace it It works fine forward but will not switch to reverse. Is there anyone here who has a similar experience and how did you rectify it? Any help here is greatly appreciated.
Connections are:-
240v with 110v control
U1 to U1
U2 to U2
Z1 to V1
Z2 to Z2
When I swap U1 and U2 on the motor I get reverse but through the same contactor
Connections are:-
U1 to U1
U2 to U2
Z1 to V1
Z2 to Z2
If all you have done is replace the motor then the most obvious thing is that the reverse switch is also faulty (maybe damaged when the motor went).
The reverse switch just does what you did manually and swap over 2 of the wires.
I would check that to see if it is actually working.
have done so, reverse contactor is working . old motor had a fault in start winding. The people who sold me the new motor are no help here. Nor is any electrician in the local area able or willing to help. seems to be a" knowledge is power kind of thing" I have the circuit diagrams. for lathe but no idea how the new motor is wired. only an uneducated guess. What Id like to know is , rather than switching U1 and U2 can the same be achieved by switching Z2 and z1.
Can you post the wiring diagram and a picture of the motor terminals and motor plate (should have the motor info)
this is a glitchy page
  • circuit diagram and connections new motor al340b.pdf
Thanks for that
I have gone through the diagrams and I would suggest you have wired it up correctly.
I assume the links in the motor that are shown on the motor plate have been taken out. I believe so or you would have heard a bang!
So I suggest you need to do some tracing to check the contactors are definitely connected and working.
That will be the KM1 and KM2 contactors in the diagram
Reverse
U1 connects to V1
U2 connects to Z2
Forward
U1 connects to Z2
U2 connects to V1
So I suggest you test these with a continuity test in the forward and reverse positions to check they make the connections as shown above.
Yes , thank you for that . I have pretty much covered all the bases that i can see.
I will persevere. I would like to know before I try, If I can switch Z1 and Z2 and achieve reverse.
It won't help from what I can see it would just change the contactor operation. By that I mean if KM1 is reverse then swapping like you suggest just means KM1 will be forward and the same for KM2 the function will be swapped.
I haven't explained the above very well because KM1 or KM2 are not actually reverse and forward it is the state they are both in that determines the rotation. They work together to swap the motor wiring around. but swapping the wires swaps the states if that makes sense.
Reverse
U1 connects to V1
U2 connects to Z2
Forward
U1 connects to Z2
U2 connects to V1
If you swap Z2 and V1
Forward
U1 connects to Z2
U2 connects to V1
Reverse
U1 connects to V1
U2 connects to Z2
Which is just the opposite of above ie contactor states are swapped in practice this would mean when you select reverse on the machine it would go forward and vice versa.
I refer to V1 because that is on the motor but is Z1 on the lathe diagram just to be clear.
It will reverse the motor but if the contactors are faulty it won't switch to the other direction.
I suspect there is something wrong with the contactors, have you actually tested them? By that I don't mean the switch works mechanically you have to be sure the connections are actually being swapped the way the motor diagram expects.
I checked the motor diagram and the connection grid you posted in your first post and I think you wired it correctly so the only logical conclusion is something is up with the contactors.
It appears not to be going from one state to the other, forward to reverse and it is the contactors that do that.
