Yes , thank you for that . I have pretty much covered all the bases that i can see.
I will persevere. I would like to know before I try, If I can switch Z1 and Z2 and achieve reverse.
It won't help from what I can see it would just change the contactor operation. By that I mean if KM1 is reverse then swapping like you suggest just means KM1 will be forward and the same for KM2 the function will be swapped.
I haven't explained the above very well because KM1 or KM2 are not actually reverse and forward it is the state they are both in that determines the rotation. They work together to swap the motor wiring around. but swapping the wires swaps the states if that makes sense.
Reverse
U1 connects to V1
U2 connects to Z2
Forward
U1 connects to Z2
U2 connects to V1
If you swap Z2 and V1
Forward
U1 connects to Z2
U2 connects to V1
Reverse
U1 connects to V1
U2 connects to Z2
Which is just the opposite of above ie contactor states are swapped in practice this would mean when you select reverse on the machine it would go forward and vice versa.
I refer to V1 because that is on the motor but is Z1 on the lathe diagram just to be clear.
It will reverse the motor but if the contactors are faulty it won't switch to the other direction.
I suspect there is something wrong with the contactors, have you actually tested them? By that I don't mean the switch works mechanically you have to be sure the connections are actually being swapped the way the motor diagram expects.
I checked the motor diagram and the connection grid you posted in your first post and I think you wired it correctly so the only logical conclusion is something is up with the contactors.
It appears not to be going from one state to the other, forward to reverse and it is the contactors that do that.
