Did a partial electric reno of a flat in an ancient building (about 60 years old) which does not have a ground wire whatsoever. The whole building doesn't have it at all, 13 floors, so don't judge me on that. I did leave the third wire empty on all new cabling I did, in case they ever decide to install a ground in the building, that at least the new cabling I did can be connected to ground. But I did a partial, so 70% of that flat's cabling is still 2-wire. They did it like that back in the day... no ground at all.
Anyway, pics 1-2 are finished work, pics 3-4 are what it used to look like. All cabling was done with 3x2.5mm except for lights/fans which is 3x1.5 (on the only 10A breaker). 16A 30mA RCBO used for the water heater as extra protection. The big one is 40A 30mA RCCB. Most of the coloured wires are the new ones I did, the gray thick ones (mostly on the lower side) are ancient.
Any constructive criticism is welcome! If you need any details I'll do my best to provide.
- TL;DR
- Old building with no grounding. Pics 3-4 are what it used to look like. Constructive criticism welcome!
