Did a partial electric reno of a flat in an ancient building (about 60 years old) which does not have a ground wire whatsoever. The whole building doesn't have it at all, 13 floors, so don't judge me on that. I did leave the third wire empty on all new cabling I did, in case they ever decide to install a ground in the building, that at least the new cabling I did can be connected to ground. But I did a partial, so 70% of that flat's cabling is still 2-wire. They did it like that back in the day... no ground at all.
Anyway, pics 1-2 are finished work, pics 3-4 are what it used to look like. All cabling was done with 3x2.5mm except for lights/fans which is 3x1.5 (on the only 10A breaker). 16A 30mA RCBO used for the water heater as extra protection. The big one is 40A 30mA RCCB. Most of the coloured wires are the new ones I did, the gray thick ones (mostly on the lower side) are ancient.
Any constructive criticism is welcome! If you need any details I'll do my best to provide.
1000022107-jpg.124216
TL;DR
Old building with no grounding. Pics 3-4 are what it used to look like. Constructive criticism welcome!
What is the upfront protection as all those breakers appeared to be linked using 2.5mm², same with the neutral bar. Where do all the earths go?
In the building hall, there's three 25A cartridge fuses/breakers. The flat gets 3 lives from those + a neutral, which are 4 or 6mm wires (i haven't measured but they are thick), not 2.5. The three small pieces going from main RCCB to all the other breakers is also 4mm. The "earths" you probably mean the bundled green/yellow wires, which have no purpose but since I did a partial (and not the whole flat), I didn't wanna cut them as they may be going somewhere that could be useful in the future. So they are just isolated with tape and bundled in the corner. Useless pretty much. Other than that, no earths. The whole 13-store building just doesn't have proper earth, it's all built on 2-wire cables. Very common in old buildings.
If there are no earths how is protection afforded?
Are there no exposed-conductive-parts?
This would not be satisfactory here in England,what happened to the busbar? Also here we run cpc(earth) to all points even if not needed at that point.
Do you not have 3 pin socket outlets or metal cased appliances like cookers and fridges there?
It is difficult to be fair when its in another country, as we have no idea of the regulations or the usual standard of work.
As above, your install would be a long, long way from satisfactory here. It looks pretty awful.
No earthing to anything, with all the earth's just bundled together with tape. 2.5mm used as a bus bar, which is likely to be undersized, so may well burn out.
Taped up bits everywhere.
Really sorry to be so negative, as I realise you feel you have made it look much better.
Even though it looks far better from the outside, the inside may well be dangerous.
Are you an electrician In Serbia, or a DIYer?
The RCCB and RCBO each trigger as soon as the difference between live and neutral is over 30mA, which means if there is a leak, they will trip and protect from shock. I haven't checked the whole apartment for exposed conductive parts but all wiring is properly done, the water heater is new and modern (and expensive) so it's double or triple isolated (or whatever, something like that), and the water heater is on it's own 30mA RCBO, taking care of the biggest shock worry (wet rooms).
Now, we do run earth to all points. That is, in modern jobs. This building is 60 years old, and does not have a ground wire, otherwise I definitely would've connected it. The sockets do have a ground pin, but it is just left empty in this case. Not optimal, but with old installation like that, the RCCB will have to deal with protection. Any leak will trigger it. Earth protection is generally rarely even needed, even tho it's a modern standard, so many of these old apartments run with no ground and no RCCB/RCBOs at all for decades with minimal problems. Again, not optimal, but they have been like that for a loooong time
As I said above, it was practically a standard back in the day: two wire cables, just live and neutral. No earths. Those bundled "earths" aren't actual earths, they are useless leftovers that could maybe prove useful in future renovations. The panel itself came with the bus bar in question, so I thought how could it be undersized if it's the one manufacturer put in? I'm an electrician but with not much experience, doing cabling and small stuff like that for about a year, and this is my first panel.
In the UK we can't rely on an RCD in the absence of an earth so it is difficult to comment on another country's requirements. Over here we would have to comply to current Regulations of any new works and ensure the existing installation is safe for continued use so if that was in the UK any new works would not be carried out as the existing installation would be deemed unsafe.
Honestly man, Serbia is so corrupt regulations don't really matter most of the time, it's chaotic af here. Last year, 16 people died when a railway station roof collapsed because the govt was doing a lot shady stuff and money laundering. No paperwork was ever published about who was responsible for the failure of that roof, victims families of course never compensated. So I'm trying to do my best to make my work safe for clients with the situation that I'm given, and in this scenario it was a flat with no ground/earth. Again, very common in old buildings, and it was safe by old standards. Re-doing the whole 13-store building PCP up to the flat I'm working on would not only be out of reach for me and my skill level, but also very much out of reach for the client financially. With the RCD and RCBO (and switches re-wired to switch off lives instead of neutral, which wasn't the case...), the flat is way safer than it was, especially in the bathroom and utility room where the water heater is.
This is exactly why we like to get international forum members on here, to show the different ways that each country approach the industry.
Like USA with their split phasing and normal to have 2 voltages (is it 110, and 220?) in the same property.
We in the UK have ring circuits, something that other countries find strange.
It’s a bit of a shock to realise that you don’t use earth wires if you don’t have the facility coming in on supply…. It’s something we have relied on for basically a century now.
If the earth isn’t supplied by the energy network, we would hammer a copper coated steel rod into the ground to achieve an earth…. And before that, relied on metallic water supply pipes…. Which now are mostly all plastic.
The old wooden fuse board would be a museum piece over here.
Hahahah yeah, exactly. Well, the building did rely on metallic pipes before (lots of them do), but someone from the lower floors changed to plastic, so all the above floors lost their earth (also very common, even tho it sounds pretty illegal to cut earth supply to everyone above you). That earth was used only for bathrooms anyway, and the rest of the installation had no third wire, no earth. I would stick a metal rod into the ground, if it wasn't 7th floor apartment lol
Also, you also have a metro for over a century, and we still don't have one 🤡
Maybe in 2030....
Doesn't US 110/220 two-phase work simmilar to EU 230/400 three-phase? Never really got into how US does it
