Question for you all, I know it may have been asked a million times so here goes:
Why is the Earth in a Twin & Earth cable not sleeved???
I Thank-you
agree, probably cost like everything these days, the csa of a cpc is smaller than the L&N so it might be a major problem when its being manufactured or something, but even then i will bet its down to £££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££.
Also under cable fault conditions only one insulation layer to pass through from live or neutral.
Ray
I Thank-you
hi there
in the production process i believe that it is used to loosely pull they cables through a continuous process and is guided on the moulding press.:)
Someone of course may know different:p
used to work years ago in a military connector processing factory :eek::eek::eek:
got a real joblater in life sparkying :D:D
cheers
Im going with fault conditions, if the line insulation breaks down (nail or were and tear) then the fault has a better way of showing up??
