Deleted member 9648
Get the fitter back DONT Pay him and possibly charge him for the refitting,retiling renewing the heating mat as I dont think thede can be "repaired" as such
Read post 8 !!
Mate just tested it. Reckons neutral has been shorted to the earth.
What does he do on the insulation test?
a screw through a 3mm cable... madness!
Have you had the whole bathroom area fitted with under floor heating.
If you have, did you inform your bath room fitter of the same.
Post 2Mate just tested it. Reckons neutral has been shorted to the earth.
He mentioned it in posts 7/8.
Yes Mark he did, I missed that.
Underfloor heating needs to be treated with kid gloves. Check the resistance after un-packing and after each and
every operation/activity to completion.
The only reason i mentioned the borrowed neutral was i asked if he had a recent board change.........If the fault wasn’t there before said fitter arrived how can it be a borrowed neutral?
If the screw (metal) is providing a fault path between both conductors then...yesI'm guessing the insulation test wont be much use now.... especially if the neutral is shorted to the earth.
Does that simply point to a screw through the cable?
