Discuss metrel instaltest 61557 again in the Electrical Tools and Products area at ElectriciansForums.net
I know you can print a test report maybe it puts the serial number on that ?? I have never used the report feature myself like but it could be worth a look.
Check your calibration certificates lads. Last time I got mine done it was printed on there. Giving them your own serial numbers is acceptable as long as the testers and all their equipment are identified by the same number. NIC registered companies I've worked for in the past have used bag numbers and they've said it was ok
That's good to know.
Many thanks for your help. :)
Reply to metrel instaltest 61557 again in the Electrical Tools and Products area at ElectriciansForums.net
Hi I’m just starting to do ev chargers so it’s looks like I need new tester. I currently have Megger 1711. So I can’t do a 6ma rcddc test. I...
Hi,… Is the N50 Series of Neff ovens a replacement for the Series 3? and secondly where can I find information on the meaning of the alpha...
I have a Dewalt 54v angle drill, the DCD470. It's a bit on the big side and I'm wondering if anyone else has one and if so what do you use to...
Hello, I wonder if anyone could help me with this unusual one-way light switch. I have changed light switches before as a DIYer but have never...
Does anyone have experience of buying surplus/second hand components? I have found some unused Siemens components, namely Motor Modules...
