O
orangegoblin
Hi Forum
I have rewired my house and then had a plasterer come in and skim the rooms. He hasn't plastered level and in some cases a few millimeters of the pattress sticks out of the plaster. As a consequence, there is a gap around the switches and they are not flush to the wall.
Do you know of any raised finger plates or something similar that can cover this up. I have already had a go at the plasterer, but i cannot have re-skim done. I am happy to use finger plates, but i have struggled to find any raised plates.
Can anyone recommend any?
Thanks in advance...
There 35mm, I was hoping there was a quicker fix...I better start digging them out. Thanks.
If you've used 35mm boxes you could change them to 25mm
If you've used 25mm boxes you're in trouble.
Have to admit id do the same ! the plasterer should do the job right in the first place ! can you not get them to rectify there faulty skimming ?
Change the boxes to plaster depth type, will be ok unless you have dimmer switches.
Being an electrician I'm sure you have thought of that already.
Sounds like you prolly didn't sink your boxes quite deep enough, or the plasterer is a total redneck (which isn't unheard of.) Taking the boxes out may bring some wall out with it so more making good. You must be able to buy raised plates but cant honestly say I've ever tried. It'll look cack too
cut boxes out with a fein multitool. no mess or replastering.
I can remember years ago in my aunt and uncle's house they had these clear plastic surrounds around their light switches. you had to loosen the switch off then slot these things around them. They were probably a couple of mm thick but looked bloody awful. They're more than likely still available and may be the solution to your problem if you don't fancy chopping your boxes in properly
how bout a patress extension collar sometime known as a skeleton box? your switches would look like surface mount but you wouldnt have a gap !!
